simple fluid flow question I hope
I need to maintain a fairly constant flow rate of liquid nitrogen out of an orifice. The liquid nitrogen is contained in a tank that has an internal pressure of 22psig. My budget is minimal, so I plan on attaching a fitting with a hole drilled though it to the the outlet of the tank to restrict the flow. The flow needs to be 250 mL/min or 0.250 L/min. I need to estimate the diameter of the hole/orifice to produce that flow rate.
I found the following thread on this forum
http://www.eng-tips.com/viewthread.cfm?qid=119094
One response noted the following equations for water:
dL = sqrt(.0444)(QL / sqrtDP)
wheredL = Diameter of orfice / in
sqrt = Square root
QL = Required water flow / gpm
DP = P1 - P2 / psi
P1 = Inlet pressure / psi
P2 = Outlet pressure / psi
or this for other liquids I'm assuming:
dL = sqrt(QL / .0001423 sqrt(DP / r))
wheredL = Orifice diameter / micrometers
QL = Liquid flow rate / mL / min
r = Liquid density
I have a few questions about the 2nd set of equations. I changed all of the units to m-kg-s. In the 2nd set of equations, the units come out to length^2/time instead of just length. Does the constant (0.0001423) have any units that might change this?
Alternative solutions or suggestions would be appreciated.
sqrt = Square root
DP = P1 - P2 / psi
r = Liquid density
RE: simple fluid flow question I hope
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying." Tony Hayward CEO BP
http://www.youtube.com/watch?v=hpiIWMWWVco
"Being GREEN isn't easy." Kermit
http://virtualpipeline.spaces.liv
