Displaying spread sheet data in title block....
is this possible? Id'e like to point a couple of dwg format feilds to one location that I can globally change.
Ex:
REV -
Job#:
Release Date:
Etc...
Would make managment of large projects a lot easier.
TIA
Dave
RE: Displaying spread sheet data in title block....
There are Expression functions which can read the cells of a Spreadsheet and this information can be assigned either directly to a Note on a Drawing or to an Attribute, which a note can also be linked to.  The only issue is that if a change is made to the spreadsheet, you have to force a manual update (which you can do with the selection of a single command) of the file so that the external data gets read.  In other words, it's a 'pull' situation, NOT a 'push'.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Well put... I could live with that if there were a way to open a batch of seperate detail files and...
1. Execute the "pull"
2. Save
3. Print
I used to do this with AutoCad. They had an external utility that could run a "script" of commands on a list of files you selected.
How about that one?????
I'm sure that could be done with NX Open.
John R. Baker, P.E.
Industry Sector
Cypress, CA
