CAESAR II
CAESAR II
CAESAR II
Please let me know about the allowable loads of piping supports in seismic and wind load cases in CAESARII. In other words, I would like to know if that allowable loads are multpiles of allowable support loads in the normal operating load case or not.
RE: CAESAR II
strsanalyst,
            Caesar II does not provide you with allowable loads for supports nor does it check the calculated loads are acceptable. A structural engineer needs to determine what the allowable loads are on an existing structure or design a new structure to accommodate the loads calculated provinig they are no ridiculously high.
I think you need to fully understand what Caesar II actually does!!!
