Suppress component and relative mating
when I suppress a component I would like that the relative mating will suppress, but not.
There is an option or I need to suppress each mating ?
If I don't suppress the mating, errors are showed in the constraints folder and it's a problem because the user don't understand if errors are relative a problem or to suppress component.
Thank you...
Thank you...
RE: Suppress component and relative mating
Isn't it about time you posted with your NX version and all the relevant information.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
sorry to forget info.
I'm using NX7 and the assembly is new with all 'Assembly Constraints'.
As the attached image I constrained some component and after suppressed.
I would like that, as in NX3, when I suppress component, the relative constraints will suppress.
It's an option, it's impossible or I need to suppress/de-select manually ?
Thank you...
Using NX7.0 and TC8.1
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
your solution works fine, but I need to add an extra arrangement.
One arrangement with components unsuppressed and one arrangement with component suppressed.
This components are '...Reference-Only' and only used for positioning fasteners or accessories.
Our BOM structure is :
1) Sheet metal machine
2) Assembly of screws
2) Assembly of accessories
As you can see from our BOM structure, to create the screws assembly or accessories, I need to add the sheet metal machine as '....Reference-Only' and suppress it.
Thank you...
Thank you...
