Multiple load step procedure
Dear All,
Good day to all,
I have an question, regarding multiple load step.
if i run analyses [for instance 50 * 12 * 2mm beam] with constraint one end and apply force in other end, i got result of stress, and deformation, and then again i want to run analyses with same model, probably constrain same but deformed model and initial stress coming out from first analyses, and apply force again and check the combination of both stress results and deformation. Is it possible in ansys, if yes i would really like to know your answer.
Thanks in advance,
Ganesh.
