performance qual test
Where do I find the test plate dimensions for a performance qual test. I have found thickness but not length and width. If I have sufficient enough material for the required mechanical tests is that all I need?
RE: performance qual test
Sec IX, QW462
Assuming structural welding, refer to Figures 4.27 to 4.33 in AWS D1.1.
candcqc
If you want more precise answers you need to provide more details.
