Suitable Dehumidifier
I'm looking at sizing a industrial dehumidifier.
First air from outside has to be conditioned (water vapour removed from the air)
Other sources of Moisture = Infiltration, Permeation, Ventilaton and makeup air, door and window opensings, people, processes and products.
Once the total lb/hr moisture is calculated, how do you determine the total cooling capacity??
I've been browsing through ASHRAE handbook but I can't find exactly where most of this would be covered. I'm searching chap 29.
RE: Suitable Dehumidifier
