How to mesh connected surfaces
i have a problem with meshing surfaces. Let's say one surface is the main one. and now we have 10 perpendicular surfaces to the main one. every one of theses surfaces are touching the main one with one curve. and now when i am meshing the program doesn't know, that for main surface there should be nodes on the touching it curves. so after meshing we have eleven plates which do not have common nodes so they work as seperate elements. so my question is how to mesh it all so it works as one element - i did it so, that i cut the main surface with these all 10 surfaces - but is it the only way? can't i have this surface as one and to make mesh correctly?
RE: How to mesh connected surfaces
else i think you can mesh the curves and then mesh the surface with existing nodes.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
