viscose rayon-304L
viscose rayon-304L
viscose rayon-304L
Hello everyone.
I'm looking for corrosion rate of stainless steel 304L, used to storage viscose rayon at 35ºC. Instead I've been looking for corrosion rate of 304L in NaOH. But I think that at pH=14 corrosion rate is practically equal to zero, isn't it?
Thanks in advance.
RE: viscose rayon-304L
Did you google Viscose rayon corrosion? I got a few hits but you'll need to buy the content. BTW how does it get to pH=14 when the industry uses a lot of sulphuric acid?
I did but didn't find anything. I know the industry uses a lot of sulphuric acid, but here only NaOH is used http://www.sniace.com/seccion2.php?id=69&area=2 , anyway I've already found corrosion rate values of 304L in sulphuric acid.
 Thanks for the help
