Optomechanical cookbook
Folks,
Could anyone recommend some practical books on optomechanical design?  I'm mostly a circuit and software designer.  I have done a moderate amount of general mechanical design too.  For my current project, I need to make a relatively small optical measurement system, and I have a principal design for it.  But in this design all component (lenses, filters, mirrors) are "floating in the air".  I need to make mechanical mounting hardware that will actually hold them.  Is there a good book that provides reference designs for lens, filter, mirror holders, etc?
Any references, suggestion, insight are appreciated!
- Nick
RE: Optomechanical cookbook
"Handbook of Optomechanical Engineering" by Aness Ahmad is a good reference and is readily available.
Harold
SW2010 SP3.0 OPW2010 SP1.0 Win XP Pro 2002 SP3
Dell 690, Xeon 5160 @3.00GHz, 3.25GB RAM
nVidia Quadro FX4600
www.lumenflow.com
reconvolution,
   Look up Yoder.  He writes books on Opto-mechanical design.
               JHG
S P I E course notes by Dan Vukobratovich is also a very good source for such information. ( or the course itself)
Writings by S. T Smith and D.G. Chetwynd  could also be usefull
Flex pivots are essentially constrained spring, so no friction or stiction, but does have forces driving it back to null.   They're most often used for limited angular travel bearings, or as part of a resonant scanner.
TTFN
