Inch sketch window size too big.
Pro/E newbie here.
Most of my parts are fairly small.
When I start a new metric file and sketch a rectangle the weak dimensions are close to my design intent.
When I start a new inch file and sketch a rectangle the dimensions are much larger than my design intent. At some point I thought I saw a way to make my initial screen zoom closer to the size of work that I normally do, but now for the life of me I can't figure out how to make the change.
Is there a way or did I dream this up?
RE: Inch sketch window size too big.
I'll use your idea for now and see how it goes. Obviously not a big deal relative to other problems. ;~)
The first plane has 2 tabs Display and Properties because it's direction is given by X axis.
the other two planes have Placement Display and Properties Tabs.
For all 3 planes Choose Display and check adjust Outline
Width and Height are in respect to the two active axes of each plane as shown below and not the direction of Plane orientation.
Plane - Width - Height
Right - Ydir - Zdir
Top - Zdir - Xdir
Front - Xdir - Ydir
The default for inlbs_part_solid.prt was 508.66 in so a small circle in new sketch still gets a huge dimension. By resizing the default planes to the average size of most of your parts you won't have to sketch a tiny line or circle and fit view each time you make a new part.
:\Program Files\ProENGINEER Install Folder\templates\
Open the template you want to modify.
Edit Definition of each Plane.
Select Display
Check [] Adjust Outline
Check [] Lock aspect ratio or enter Width Height info as described in the table above
Enter the value in inches for plane sizes along edge
Hit OK
Michael
