Measuring the OD on a 11 tooth gear
What would be the best way to measure the outside diameter on a 11 tooth gear that is under an inch in diameter.
RE: Measuring the OD on a 11 tooth gear
Measure the radius from the bore to the tip of one tooth. Multiply the result by two and add the bore diameter.
Ron Volmershausen
Brunkerville Engineering
