Transient Thermal-stress analysis
Can anybody help with issue of transient thermal stress? I managed to make thermal transient analysis, change et and get some structural results using thermal results. But i've obtained only static solution (as i read in help - ansys takes only first or last result from thermal transient file) so i have displacement at...the end of analysis i think...
So - how to force ansys to make nice animation about how my object changes it's shape during cooling?
RE: Transient Thermal-stress analysis
1. use direct coupled field elements and you can post-process the animation as required
2. for each time step that you have done a (sequential) thermal-stress analysis run, export out a plot in the same orientation and scale. Then, use a graphics program to create an animation from the plot files. Of course, you may also do this using the .grph files from ANSYS with some APDL scripting
but according to the se2nd option - is there possibility to import thermal temperature result file entirely (lets say my 100 substeps) or i have to solve problem 100 times, reading .rth file with different substep?
thank
sebastian
