Solidworks 2010 Help!
Hello, I seam to have a problem and am hoping that someone can help. In the past, I had a student version of solidworks installed on my computer and now it is time to upgrade. I have purchased solidworks 2010 premium. The problem is I have completely uninstalled the educational version deleted the registry like other forums have said but when I install premium every time I make a new part it still saves in the educational version. I am able to modify already existing parts and save them but can not create a new file and insert into a assembly. I need to know how to completely uninstall the educational version along with everything that comes with it. Any help is greatly appreciated. Thanks
RE: Solidworks 2010 Help!
A simple search of the FAQs yields this gem: http://www.eng-tips.com/faqs.cfm?fid=488
- - -Updraft
The following from the official SW Forums should do the trick.
https://forum.solidworks.com/docs/DOC-1014
But if that doesn't work, reformatting your drive may be the only option.
Personally, in cases like this, I would do a complete format and OS reinstall. Looks complicated but sometimes it's easier and faster, just back up everything on a separate drive and double check everything (docs, bookmarks/favorites, passwords etc)
Tony Greising-Murschel
Windows 7 x64
Core i7 870 - 8GB
Nvidia Quadro FX 580
SolidWorks 2010 SP3.0
