Preferable method to set in wear rings
Wear rings at shaft and impeller can be set in place by either welding, by axial set screw or radial set screw. Which methods are most preferable and why? the inquiring mind wants to know. thanks.
RE: Preferable method to set in wear rings
Would radial screw be acceptable? Wear surface will wear down and any exposed radial screw head would score the shaft.
Of course all of the methods are compromised if you start with a poor fit of the ring to the impeller.
Thank you for your response. I thought radial screwed wear ring would not be the best choice due to concern over local scoring when the screw head are exposed when the wear surface wears down. Can you elaborate on the difference of both radial and axial screwed type? I'm new on this. Look forward to reading your response.
Johnny Pellin
Johnny Pellin
