shell offset easy quesion
HI ,what is the difference between bottom surface and top surface?
what criteria show me which one to choose? maybe the axis orientation or the magnitude of the surface? thanks
RE: shell offset easy quesion
By default, shells are at the mid-surface, but it is possible to change this in the shell definition. Also, you can plot shell normals in Viewer.
Martin Stokes CEng MIMechE
