Pitch dry fiber UD
Pitch dry fiber UD
Hi all,
I am looking for a Unidirectional fabric of pitch fibers (Dialead K13C or D, NGF YS-80 or 90).
It is for a thermal conductivity improvement study of CFRP.
Do you know who can supply this fabric?
RE: Pitch dry fiber UD
So yes I am thinking to do it in-house with the winding machine. But I also wondering what solution I have to bond the fibers to be able to handle them ( I have to lay them flat).
Simple tape at the edge, binder that dissolve in the epoxy...?
There is also a heat fusible scrim available at sewing shops, that is designed to iron onto fabrics to stabilize them. This works well if your end use temperature is not very high.
