SWX and Windows 2000pro Swap file size
Is there a recommend swap file size that needs to be setup when using SWX office and windows 2000 professional?  I know Windows 2000 has a better memory manager and on previous windows environments it was recommended that a swap file be created 2-4x's the ram size.  Does anyone know what is recommended on Windows 2000.  Currently 2000 sets up a swap 2x's the ram.
Thanks for your feedback.  I am in new territory here.
Dean
Supreme Corp.
dean.weldy@supremeind.com
RE: SWX and Windows 2000pro Swap file size
I have mine set for 3x for min. and 4x for max. under windows2000.
BBJT CSWP
"Experts" recommend that whatever the virtual memory is set to, that the min and max values be set to be the same.(min=750mb, max=750mb for example) I have used 2x with 512mb and with 1024 mb ram.
