ADV SIM / Nastran units?
Hi folks :)
Perhaps a bit silly question but nevertheless:
How can I define default units in NX to be mm, metric tonne and N? Whenever I change the units via custom unit manager, it's ok and unit info shows me the correct units.
But the problem arises when I generate Nastran input deck (.dat), where other units are defined (kg, mm, mN). I have also seen the parameter UNITSYS in .dat file, which is supposed to be used by NX only.
If I read/import results back to NX it's all ok, but the problem is when importing to other apps (which unavoidably I must do).
Therefore: how can I set the units, so that would be mm-t-N unit system in .dat generated from NX?
Many thx and have a nice day!
br, Bojan
RE: ADV SIM / Nastran units?
Hi
this is my first post in Eng-Tips Forums
I don't see any default settings about the nastran file units in NX advanced Simulation. the default setting is mm-mN-kg.
but in some cases our customers want mm-N-tonne or other unit systems.
to do this I use the export simulation option (File -> Export-> Simulation)
here I can select the unit system while creating the nastran input file. and then I execute the nastran.exe and solve the input file.
While postprocessing the results I import the .op2 result file and select the unit system for the results.
akilic
