references on technique of LNA disconnection
I am searching for references (papers, books) about solutions to protect a LNA in receiver from leakage signal from the circulator when in transmit mode (circulator is connected to transmitter, antenna and receiver).
The LNA is behind a switch.
I have read on this site that a solution would be to disconnect the switch from the LNA when transmitting and connect it to a 50 Ohm load.
Can anyone please point me towards a publication that discusses this?
Thank you very much!
RE: references on technique of LNA disconnection
