sizing of nitrogen purge nozzle
Dear Friends
I have a pentane tank 20000 m^3 capacity and i want to know what size of nozzle can i use for Tank  Nitrogen purge ?is there any references for it?
RE: sizing of nitrogen purge nozzle
Do some flow calculations.
What's the capacity of the pump?
Greetings
Make it the same size as N2 pipe that brings the N2, alternatively you may make it one size larger. For example, if the N2 line is a 2", you can also make the nozzle 2" or 3".
That should do it..
I hope you do know what size the N2 line is!
