Import geometry from ANSYS Workbench to ANSYS Classic
Hi all,
I have created my model in ANSYS Workbench. I have meshed it also. Now I want to import it to ANSYS Classic for modal analysis. How can I do it?
RE: Import geometry from ANSYS Workbench to ANSYS Classic
If you want to take the FE model (only) into the classic environment, you can either write out a DB file after solve (check the Details options in the Analysis Settings branch), or write out an input file after applying basic loads from the Tools menu.
