Ti-6Al-4V ANNEALED PLATE
Does anyone have a full (or partial) range stress-strain curve for this material in the thickness band encompassing 16 mm (5/8")?
Thanks in anticipation.
RE: Ti-6Al-4V ANNEALED PLATE
MIL-HDBK-5J (p.5-66) gives a full range stress-strain curve for annealed 6Al-4V sheet at RT conditions. The difference in mechanical properties between annealed sheet and annealed 5/8" plate are probably less than 5% (since they are both wrought forms), so maybe that is adequate for what you need.
Hope that helps.
Terry
Louis
MIL-HDBK-697A (p.45-46) has some limited fatigue data for wrought 6Al-4V Ti that may be of use with your M&P guy.
Good luck.
Terry
Louis
