Ansys workbench Beam contact
Hello. How does I make contact between beam and face in Ansys WB? Thank you.
RE: Ansys workbench Beam contact
You could attach solid elements to the beam in the area of contact and use normal contact elements. You can do this in ANSYS classic.
Chris
www.value-design-consulting.co.uk
This can be done with using the MPC methode in the contact settings.
I tried MPC, but I can't select beam as contact. Do you know any command example for beam to surface contact. Thank you.
