Pad problem (Challange) :) CATIA V5
Hi everyone
With this part in da PIC iam trying to use the Pad function for my sketch as u see. The problem is that I want to pad my sketch along the surface which has an angle. And I want my sketch to be smaller and smaller along the body. PLEASEE help, appriceate video help too, (new user)
Best regards
Best regards
RE: Pad problem (Challange) :) CATIA V5
Cheers,
Mark
that does not work,
If the whole section is changing then use loft or multi-section solid as I believe it is called now but you need a section on the receiving end.
If the section change is related to a draft then pad the section you have, check the options, think there is a way to merge it in one shot with the main solid, and then use the draft function.
I'm not a V5 station now so I haven't had a chance to test my theories but hopefully it will point you in the right direction
