SoliEdge ST2 - Thread problem
I'm a new user of SolidEdge (ST2), I'm use ST2 MP6...
When i thread a hole, a message appears : no correlation with the file Holes.txt ... despite I used a hole Ø that exist on the "Holes.txt" file?
For information, I have set up "regional and language options" of windows to use "." and not "," on SolidEdge, therefore, my problem does not come from this.
Somebody have an idea?
Thanks.
Thanks.
MERMET Sebastien
Mecanical & Product Designer
SolidEdge ST2 & Unigraphics NX4 & 6
RE: SoliEdge ST2 - Thread problem
If that is the case try changing the hole type from simple to threaded, and then select the appropriate thread size from the list. You will save having to create a seperate thread feature.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
Thanks, I use this solution on my design...
But I search a solution for imported files.
Best regards.
MERMET Sebastien
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
bc.
Quadro FX4600.
Where is this fonction is located?
Thanks...
Regards.
MERMET Sebastien
(sorry to be a bit vague but my work id now on catia v5)
bc.
Quadro FX4600.
