Weight calculations
Weight calculations
Hi!
Running NX 5.0.5.3 and TC 2005we are currently using the method of adding the casting to an "assembly", Wave-Link the casting body to the "assembly" and perform the machining in that same "assembly"
However we have problems with the weight calculation on the machined part. It adds the weight of the casting body to the weight of the machined part. So if the casting has a weight of 10kg and the machined casting a weight of 8kg the weight adds up to 18kg instead of the expected 8kg.
We have the advanced weight management license and I have tried creating a specific Ref.Set called "Weight" were only the machined body is selected but it still does not work.
The only way I have obtained a correct weight is by suppressing the casting but this seems to be such a drastic way to do it.
Any ideas anyone?
Best Regards
Martin
Any ideas anyone?
Best Regards
Martin
RE: Weight calculations
The following thread might be of some help.
http://www
Thanx for the thread, could not find it by myself (an still can't).
Suppression seems to be the way to go, but I can't shake of the weird feeling that with all the functions that is within "Advanced Weight Management" there should be a smoother way. Machining on castings could not be so uncommon and that NX can't seem to deal with it in a smart way is weird.
Best Regard
Martin
