simocode pro v device 46 settings
Hi everyone, we are designing a water treatment plant. There are several pumps and compressors. The client wants to use Siemens simocode Pro V relays, but I don't know the range avaible to set the unbalanced load relay (% of unbalance or delay), niether the setting I should use. I surf all over the Siemens website, and nothing.
Thanks in advance
Thanks in advance
RE: simocode pro v device 46 settings
The best thing to do however is to discuss it with the motor suppliers. What you will find on the web will all be in reference to Voltage imbalance, with a mention that the current imbalance is an exponent of the voltage imbalance percentage. But the motor mfrs can relate the heating effect of a current imbalance to the thermal damage curve of the motor.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
