Create New Subassembly
Hello all,
I know you can create a new subassembly by selecting parts in the assembly tree and then doing a RMB on the last selected item and then going to form new subassembly here.  Is there some way to do this by selecting the items in the assembly instead of the the assembly tree.  This would be MUCH easier.
RE: Create New Subassembly
BodyBagger,
   I still am on SW2007 here.  Is there any way to click on something and get the sub-assembly rather than the part?
   If not, you are clicking on the assembly tree.
   The assembly tree works fine for me.  If your file naming is not intelligent, try sticking your items in folders, and then name the folders.
               JHG
AFAIK, a new sub-assy cannot be created from within the graphics area.
FYI, the last selected item (in the FM) does not have to be the one RMB'd. Any one of the selected items can RMB'd.
You can select a bunch of parts in the graphics area and select Isolate.  Does that help with creating subassys?
Dan
www.eltronresearch.com
Dan's Blog
CBL, if I RMB on anyone other than the last one, then they all deactivate (no longer highlighted) except for the one I RMB on.
SW2010 SP2.1
Strange ... I believe I've always been able to click on any. The highlight may go away, but all the parts are moved into the new assy.
This might seem like a silly question but what is RMB?
Thx
-TBUC
RMB = Right Mouse Button
