sweep cut along complex path
I need some help making a half circle cut out along this path...
I want to sketch a path as shown by the green line in my picture and then sweep a cut along it. how do i do this?
http://i58.photobucket.com/albums/g254/asv4k8/cutpath.jpg
thanks in advance
RE: sweep cut along complex path
What have you tried?  What problems are you having?  Have you checked the Help for Sweep?
Dan
www.eltronresearch.com
Dan's Blog
I have tried to sketch a path on the surface of this but have not been able to on the non-flat ie compound curved surfaces.. once i have a path i think i can just sweep a cut along it but no luck so far.
Try to use intersecting surfaces to your advantage when doing something like this.  Create a 2D sketch for your path then extrude a surface.  The intersection of your new surface and your complex surface should be the final path that you are looking for.
Dan
Dan's Blog
ahhh good call i will try that and see what happens thnx sir
