Measuring current inside a delta connectioin
When measuring current inside a Delta connection what would you expect to read if you put a clamp on meter around two legs of the delta connection. I know each leg would have 58% of the line current just at different phase angles. Would a clamp on meter account for this phase angle differene and show the two individual legs adding up to the same as the line current?
For instance lets say on one phase coming into a delta connection we have 100A on the line. Now if we go inside the delta and measure the combined current where this line splits off into the two dela legs will we see this same 100A while meausing both legs simultaneously with a clamp on? Or will the phase angles not seen by the meter lead to an error?
RE: Measuring current inside a delta connectioin
Rafiq Bulsara
http://www.srengineersct.com
However if you clamp around both legs after the line splits although the meter only reads magnitude would the 120deg offset of the delta current fields cancel to some degree to leave you with the same magnitude as the line current shown on the meter? Maybe this is what LionelHutz is implying?
I guess maybe I was getting confused due to the fact due to the fact there was contributions from other phases inside the delta and the current simply wasn't splitting off a single phase feeder.
If you encompass multiple conductors, the clamp on meter or a CT would read the magnitude of the Net current after the vectorial addition.
Just as if you pass back the same conductor through the CT (canceling each other) it will read zero current or if you place double turns of the same conductor through a donut CT you will read twice the magnitude.
Rafiq Bulsara
For AC circuits, you always have to sum vectorally.
Yes, if the currents in 2 wires sums to 100A then the magnetic fields produced by those wires would sum to the equivalent of a 100A field when side by side and inside the current clamp.
