work examples of footings in biaxial bending to ACI 318
Are there any work examples of pad footing design to resist biaxial bending based on ACI 318? I only found some simple examples from a number of textbooks.
I wish to thank you all in advance!
RE: work examples of footings in biaxial bending to ACI 318
Unfortunately, the example provided is applied for bending in one direction only. But I had solved this problem using Excel last week. Footing was considered in 100 slices and soil pressure in each slice is assumed to be constant along its thickness direction. A sum-up of the bending moment of each slice about the critical section will give Mu. In terms of the accuracy, 100 slices are acceptable.
Cheerio
Oversee
