Patran composite sandwich structure modelling
Hello everybody I could really use some help in modelling sandwich coupons (a honeycomb core between two composite faacesheets) in Patran/Nastran. I am new at the software so excuse me if my questions seem too elementary.
I have identified three methods in which I can model my sandwich.
1) I can model each composite ply and the honeycomb core as a 3-d. My question is when I create each ply as a group how do I specify the bond strength and contact type with the other lamina? I will be looking at interlaminar failure so this is important to me.
2) The second method is modeling the facesheets as a 2-d with the core being 3-d. I will draw a 2-d surface then using PCOMP I will assign the ply properties, however, when I want to "bond" my facesheet to the core do I have to offset by the thickness of my laminate or can I just place on the face of my 3-d core
3) My third method is to just model the whole thing using PCOMP.
Also if someone can tell me the advantages and disadvantages of modeling using one method over the other I would be very appreciative.
Thank you so much,
Thank you so much,
RE: Patran composite sandwich structure modelling
What exactly are you modelling and why? what is the shape/configuration of the structure? how is it loaded? what are the boundary conditions? what do you want to get from the model? displacements, stresses, or something else? what are you going to do with those results? do you have test data to compare the analysis results to?
I hope this helps, if you have any more questions just ask.
