Seed and Boundary Surfaces
I am trying to add draft to numbers and tick marks that protrude from a cylinder. Some of the items draft with no issues while others return a "seed and boundary surfaces" message on the screen. What does it mean and how do I fix the geometry? I am using WF4.0
Thank-you,
Arnie
Thank-you,
Arnie
RE: Seed and Boundary Surfaces
I couldn't tell from the file what the problem is, however, individual surfaces, seed surface and boundary are two methods of selecting surfaces, if you are selecting surfaces individually, press and hold Ctrl key to add to your selection set while you are selecting other surfaces, if you are using seed surface and boundary, select the seed surface first, press and hold the Shift key, select the boundary surfaces, release the Shift key and you will select all surfaces limited by the boundary surfaces, the selection set starts from the seed surface.
I hope that helps
Michael
Arnie
