Back calculating surface roughness
thread378-220785: PVC pipe absolute roughness
I have read a number of posts on this site which mention "back calculating" to find the roughness of a pipe/hose (see link). I have a fabric duct used for HVAC which was sent to us for R&D purposes from the manufacturer. I am having trouble back calculating my test results to find the duct roughness. It's a simple fix surely -- can someone outline in detail their process for calculating epsilon?
Thanks in advance
Thanks in advance
RE: Back calculating surface roughness
Solving a Colebrook or similar fluid head loss equation for ε isn't on my priority list.
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying." Tony Hayward CEO, BP
"Being GREEN isn't easy" ..Kermit
http://www.youtube.com/watch?v=hpiIWMWWVco
http://vir
For flow in a duct the flow is probably fully turbulent and you can use the rough pipe law:
1/√f = 2Log (3.7D/ke) or
(1/2)1/√f = Log (3.7D/ke)
Take the anti log of both sides and get:
10(1/2)1/√f=(3.7D/ke)
Solve for ke:
ke=(3.7D/10(1/2)1/√f)
f is the Darcy friction factor
D is the pipe diameter
ke is the effective roughness
You can do the same for the Colebrook equation.
Thanks for the help! I iterated per the instructions of BigInch and received the results I needed.
The equation you provided gave me near exact results to those which I iterated. However, it is handy to have an equation which Excel can equate for large amounts of data.
In hind sight I should have tried to solve for the Colebrook equation rather than the Haaland equation since the Haaland equation is derived from the Colebrook equation.
Thanks again BigInch and vzeos.
