Can I make ramped CONSTRAINT EQUATIONS?
Hello!
I use constraint equations (CEs) for preloading internal nonlinear parts in my model - basically sets of rolling bearings. The problem is that the immediate introduction of the CEs provides very sharp loading effect and causes convergency difficulties.
I can explain the problem on a simplified 3-node model with a 1D nonlinear spring which looks like:
D*CE*/\/\*D
Legend:
*     node
/\/\  combin39
D     displacement constraint on a particular node
CE    preloading constraint equation between both nodes
Question: Can I smooth up the introduction of CEs? What about gradually increasing constant terms in CEs? There are a lot of CEs in my full model, so restarting and changing the constant terms manually would be very inconvenient.
Any ideas? Thanks!
