Liquid/Molten Sulfur specific gravity
S!
Anyone knows/has the variation of liquid/molten sulfur as a function of temperature?
Cheers
RE: Liquid/Molten Sulfur specific gravity
From the CRC manual:
The density at the melting point (115.21oC) is 1.819 g.cm-3
Between that temperature and 160oC use:
ρt = 1.819 g.cm-3-0.0008(t-115.21oC)
S!
Thanks!smile
Surprizing you haven't asked about viscosities.
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying."  Tony Hayward CEO, BP
"Being GREEN isn't easy" ..Kermit
http://www.youtube.com/watch?v=hpiIWMWWVco
http://vir
S!
BigInch, my issue is with volume to mass conversion of a liquid sulfur tank.smile
Flow properties, in this case, are not my concern.
You're the lucky one.
http://vir
