Coatings for aluminized metal
Need advice on surface preparation of aluminized carbon steel items prior to priming/top coating.End use is for 100% exterior exposure, year-round, Central MidWest.  Land, not marine, application.
Thanx.
bobxman1
RE: Coatings for aluminized metal
Need more information.
Exactly what type aluminized steel do you have?
If it as brand name contact the manufacturer and ask about a coating or you may contact a knowledgeable coating supplier.
If it is thermally applied what was the method?
The recommended preparation is similar to other metallic parts - alkaline clean, zinc phosphate pretreatment, then paint.
From whom do you obtain the steel and the paint?  You can contact each for more information on your application.
