cord rotation
cord rotation
cord rotation
Hi
For example take a rectangular block having 4 holes or slots on 4 sides like B0, B90, B180, B270...I generated program B0 is main Remaing all "LOCAl" but Special Output I used "USE MAIN MCS" bcoz my work offset(G55) same for all 4 sides.
My program verification shows everything perfect ,  But when I post the nc output at B180 side "Z" values appering in "Y" , "Y" values appering In "Z" so how to change this.
And also I am not getting "B" value in my out put at B180 side.
Just see pic what I attached.
pls help me how to comeout .
soory for my English yaa
Thnks
UGNX6
RE: cord rotation
You would likely be better off posting this on the Machines & Machining Engineering forum.
http://eng-tips.com/threadminder.cfm?pid=281
Engineering is not the science behind building.  It is the science behind not building.
