Cable selection in Harmonic enviornment
When we are sizing the cables in a harmonic environment, the harmonic levels ( current and voltage distortions) are controlled within the IEEE 519 limits, we normally follow CEC and NEC to size the cables, do we need to increase the sizes due the existences of the harmonics?
RE: Cable selection in Harmonic enviornment
Also I am intereted to know if we can use Non-inverter duty motor in Harmonic controlled envirment (within IEEE limits).
Thanks in advance.
