Appropriate Neoprene liner for offshore riser clamps
Hi Guys,
I am wondering if you can help me specify a riser clamp neoprene liner that would work effectively in marine environment.
RE: Appropriate Neoprene liner for offshore riser clamps
Many thanks Steve appreciate it,
I checked it out and seems great yet I am still wondering if the same compression set requirements apply to the clamp liners?
Any thoughts about the acceptance criteria for seawater absorption & ozone resistance for such application?
Seawater absorption:
- Max 5% volume change
- Reduction in tensile strength max 15%
- Change in hardness max +5/-5 units
- No cracking, crazing, blistering or splitting after immersion
Ozone resistance:
- No cracking or 'other detrimental effects'
Steve Jones
http://www.oilandgaspeople.com/cv/11499664
http://www.linkedin.com/pub/8/83b/b04
Thanks Steve, actualy thanks twice for the two replies smile
much appreciate the expert advice
