Westinghouse 15kV Oil Circuit Breaker
Might anyone have a source for or a copy of the schematic or wiring diagram for two old Westinghouse 15kV OCBs,  B-28-B and B-22-B.  I have the instruction book for the B-28-B breaker, No. I.B 5706A dated 9-42, Filing No. 33-000.
RE: Westinghouse 15kV Oil Circuit Breaker
Likely the wiring diagram I or anyone else posts would be worthless to you, most of those were wired to the customer spec. And it may have been modified over the last 50 years.
The owner of the equipment should have it. If not, you will need to trace out the wiring, only way to be sure it is right.
