control the size of Datum1
I want to set up the datum1 in ordinate dimensions origin from part defaults. I'm able to to so for the standard size d= 10mm, but I can not setup a size d=3mm. Is there something like size control string for the datum1 - scaling or any ideas?
thx in ad
thx in ad
RE: control the size of Datum1
i solved editing the ug_standard.sbf file -very tricky ;)
