absolut rotary encoder 100.000RPM
Can you help me with this ???
position feedback: stand still ... 100.000RPM
resolution: 1 < Degrees < 6
output signal: parallel 7...8BIT ore SIN&COSINE
operation temp.: -25...>=+100°C
Boundary conditions:
high internal EMI magnetic up to 100mT
electric up to 100V/m, high BW
displacement of shaft
axial + - 200um
radial + - 100um
very limited space outside diameter < 70mm
inside diameter > 35mm
thickness ca. 10mm
including disk, airgap, sensor PCB
do you have an idea or clue ???
thanks
micmad
axial + - 200um
radial + - 100um
thickness ca. 10mm
thanks
micmad
RE: absolut rotary encoder 100.000RPM
mech. accuracy is poor.
100 thousand rev/min is the max. What is the minimum ?
100 micron displacement seems to be excessive.
How much is the max. acceleration?
Could you tell me more about the application?
<nbucska@pcperipherals.com>
http://www.thomasregister.com
and type Encoders: Absolute under Product or Service, which will return 85 companies to contact regarding your spec feasibility.
