Specific heat
Specific heat
Hi everybody.
I wan't to input a number with the unit J/Kg * degrees cesius.
but when i add the celsius unit after i typed kg and ''*'' it becomes red.
anyone who knows how to input a specific heat unit?
TIA
TIA
RE: Specific heat
Degree Celsius has been a long-standing annoyance in Mathcad, since it is sometimes used as a delta temperature, and is completely equivalent to a kelvin, while other times it's used as a psuedo-absolute unit, and is equivalent to the kelvin temperature minus 273.15K.
In M11, I use kelvins for all temperature related calculations; you just have to subtract 273.15K if you want Celsius temperature.
TTFN
