Galvanic Corrosion
Galvanic Corrosion
Good Morning.
Can dupplex stainless steel Gr.5A and 254SMO(CK3MCuN) be welded in seawater condition?. I think there's no problem with galvanic corrosion, since they have nearly the same corrosion potential, but I need to be sure, if anyone could help.....
Thanks in advance¡¡
Thanks in advance¡¡
RE: Galvanic Corrosion
Since you are welding a duplex you should make sure that your weld qualification includes A923 testing. You wouldn't want to be forming detrimental secondary phases in either alloy.
Plymouth Tube
Galvanic Series Seawater
S
Corrosion & Rust Prevention Control
