Pressure, Volume, Time - equation to relate these values
Hello there,
I'd need an help from you concerning pressure, volumes and time.
I tried to find something in past post, but with poor success.
Following is the issue.
I have got a compressor, and I now that for increasing pressure of a volume of 50 l of air from 1 to 120 bar it takes 100 minutes.
From manufacturer I know that for the same increase of pressure, I'd need for 1l, 1.2 minutes.
I suppose I'd need other values like volume displacement of the compressor.
Nevertheless I'd like to ask you if you know - or if exists - some equations that would allow me to calculate:
- ex: how long it will take me to increase the pressure to 120 bar of a volume of 22 l
- how long it will take me to increase the pressure of 50l to 120bar if I would charge previously this volume at 32 bar.
Many thanks for your help !
RE: Pressure, Volume, Time - equation to relate these values
No.
No realistic compressor takes a 100 minutes to go from atmospheric to 100 bar ...   The one I used (well, hired actually) last night did it in a few revolutions of the crankshaft.
Check your numbers again please.
The power rating of your compressor will determine how long it takes to compress a certain volume of gas.
           compressing gas requires work.
           work/time = power
           Calculate work and divide by power available
Remember now?
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying."  Tony Hayward CEO, BP
"Being GREEN isn't easy" ..Kermit
http://www.youtube.com/watch?v=hpiIWMWWVco
http://vir
Time depends on volume you are pumping into AND the ever changing volumetric efficency of your compressor. Going from 1 to 120 bar, the VE has be extremely low as you approach 120 bar unless you have a 4 to 6 stage compressor.
so use the equation for VE found in the GPSA databook.
