Foward - reverse 1ph
Hi
I was wondering if anyone could help with a digram to make a motor go forward and reverse, ie this will be on a car lift that will run up and then down.
The motor is single phase 3.7Kw 1ph 230V, 50Hz with centrifigal switch.
The block is as attached.
Very much appreciated
RE: Foward - reverse 1ph
I cannot get a good image of the nameplate, but it is a WEG 112 frame cap-start-cap run motor 3.7Kw 4pl 230V 1ph 50Hz
See attached images, and tanks for your reply.
F.E.G
CAREFULLY record the winding connections. If the leads are not labeled, label them yourself.
Disconnect the leads. Use a suitable continuity meter to find the other end of the start winding.
Reverse the leads for the start winding.
Bill
"Why not the best?"
Jimmy Carter
