Conversion help
Conversion help
I have been asked to convert an .stp file to an .igs file & wondered if anyone could point me in the right direction please.
Thank you
Thank you
RE: Conversion help
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
RE: Conversion help
A potential client has asked the question.
As long as you have the software then it sounds a straight forward process.
Thank you.
RE: Conversion help
It IS just as straightforward as MadMango describes it. However, if the file has gaps in it or other problems you may not have such an easy time, i.e., crap in equals crap out.
A few comments/questions:
1. Whomever is creating the file in STEP format can probably save it out directly as IGES.
2. What is the purpose for the IGES file? It is not really a preferred format for solids.
- - -Updraft
RE: Conversion help
What software does you client have? Most 3D programs can read both STEP and IGES.
STEP is generally the better (reliable and cleaner) format than IGES.
RE: Conversion help
