Pictorial section view
I am trying to do a Pictorial section view(1/3 of the section removed). I imported a Isometric of a shaft & with some of the rings & bearings assembled together. I want to show a Pictorial section view. I try to read the drafting documentation. But i failed to understand what expalined there. So could some help me to expalin how it is done. If video file will be a greatfull help for me. Thanks in advance.
Vijay
Vijay
RE: Pictorial section view
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX6.0.3.6 MP2 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
Thanks for your reply. Yes i am lokking for this. Your's is a simple model. My one is a assembly. I want to show part in a section view. It is very hard for me to show all the parts in a revolved section. So i planed to add another pictorial section view. This is full fill my needs in my drawing. I read documentation but it is hardly expalined over there. I tried many times only i get the sections over a plane not like this(1/4 section removed). So please help me to explain how to do this type of similar view. If it is a small video file it will be much helpfull. Thanks in advance.
Vijay
Find attached an avi, I hope this help
Didier
Here is another set of instructions for an alternative method of creating a section cut through a pictorial view called Break Out Section, I hope it helps you, let us know how you get on. :)
Best regards
www.jcb.com
Thanks for your video. This is what i really trying for. Really thanks for amking a video clip to explain.
Hi JCB,
Really thank you too. This is the another way to do the section. Thanks. Both i can use it the way i need it.
I am sure you guys helped me a lot also it may be usefull to others whoever need it.
Vijay
